by mollieb
Is it free to text a friend on holiday in Sardinia from the UK?
Hi I'm unsure if i would be able to text a friend staying in Sardinia without being charged extra. Can anyone help? Thank you.
by Ace Contributor
Solution
Re: Is it free to text a friend on holiday in Sardinia from the UK?
HI,
@mollieb
You can send text UK Mobile number from UK free off cost.
There will not be any extra charge for that.
by Ace Contributor
Solution
HI,
@mollieb
Great answer @tahirmian
Hope that gives you what you need @mollieb
Cheers
Richard
