by keithy397 Contributor
Is it free to call Ireland?
Is it free to call Ireland on landline and mobile?
Solution
Re: Is it free to call Ireland?
No, that would be an International calls from UK & is chargeable. You would not be roaming. Text CALL ABROAD to 150 to get these calls & texts at cheaper-than-standard rates.
7 REPLIES 7
Hi and thanks.
I forgot to ask. What about when I'm in Ireland. Do I need to do anything to get free roaming & calls?
Cheers,
Keith
Solution
Thank you.
EE Employee
Hi and welcome to the community @keithy397
Hopefully, the advice above has helped with your query.
Many thanks,
Lee
When you are in Ireland you are roaming. Then your UK allowances are valid there as well.
Make sure you text ROAMING to 150 well before you leave here to ensure roaming is enabled on your a/c.
Thank you, again. You've been a great help.
Cheers,
Keith
Thanks! You're welcome :)! Glad I could be of assistance.
