by RMcCulloch
Is it an English auto voicemail voice when someone calls you while your abroad?
I received two voicemail messages while I was in the away abroad from a number I did not want to know that I was abroad. My phone was switched off or in airplane mode so it would have gone straight to voicemail, but is the automated voicemail voice as the uk one is? I'm worried they would know i was abroad if it was automated foreign or different
Solution
Re: Is it an English auto voicemail voice when someone calls you while your abro
No don't worry,  if someone calls your voicemail when you are abroad they still get EE normal (English) message.
6 REPLIES 6
Solution
by Brilliant Contributor
It's the same voice as if you were in the UK.
It doesn't let anyone you are abroad.
Also you will be charges for these as roaming rates which will show up on your bill as your own number.
by Profile closed
Not applicable
Yes EE use a chipmunk version of the Orange voice now. 😄
Orange was always the fun network way before Three. Shame.....
by Profile closed
Not applicable
@Northerner aha you mean like this?
https://m.youtube.com/watch?v=QGp5uWwGQLk
Best advert ever!! Fact! 😄
Good morning @RMcCulloch.
Thanks for coming here.
As above this will not change when you are abroad 🙂
You will only be charged if you listen to the message.
Full Roaming information can be found on our Roaming post
Hope you are having a great time!
