by annewilko63
Is data, text and calls from abroad, free on payg?
Are calls, data and texts free from abroad on payg?
by Profile closed
Not applicable
Solution
Re: Is data, text and calls from abroad, free on payg?
Hello @annewilko63 not necessarily no it depends what plan you are on, what roaming add ons you have active on your account and which country you are in. Incoming/outgoing roaming charges can be found for your destination using the roaming tool contained in this link. :):
https://explore.ee.co.uk/roaming
by Profile closed
Not applicable
Solution
by annewilko63
Thanks Tom
by Profile closed
Not applicable
You're welcome @annewilko63 enjoy your time away! Come back to the community anytime if there is anything else you would like to know. 🙂
Do you mean while abroad? Then, no. your PAYG allowances are only for use from the UK. While abroad you will need to buy add-ons and/or pay for calls & text from your PAYG credit. See www.ee.co.uk/roaming for rates.
