by csav
New Member
Is data roaming in usa free?
That's basically all I want to ask, just got a new contract with EE and just trying to realise if I've been screwed over with data roaming when I could have got this for free on other networks.
Re: Is data roaming in usa free?
Hi @csav
Welcome to the community. 🙂
If you're on a Max Plan taken after May 2017 or have the Roam Further add-on or swappable active, you'll be able to use your normal allowances when in the USA (up to 15GB data).
If you're not on one of those plans and don't have the Roam Further add-on or swappable active, you'll pay normal USA roaming rates for calls and texts and will be prompted to purchase a roaming data add-on when you try to use your phone for mobile data.
Please text ROAMING to 150 to make sure your phone is set up for roaming.
Hope this makes sense.
