by Robert89 Investigator
Iphone 7 won't make calls to the UK from Ireland
I have moved to EE from O2. I have all my details changed over and I have the Roam at home package. My issue is that I cannot make calls from Ireland to the UK. I work in Ireland and live in Northern Ireland.
Even with 0044 or +44 in front of the numbers I need to call it won't work. Can someone help me please?
Thanks,
Solution
Re: Iphone 7 won't make calls to the UK from Ireland
@Robert89   That doesn't enabled roaming on your account and can in fact stop your device from working on a roaming network. That's an option that Apple put on the device that not   applicable to EE
Text ROAMING to 150 to enabled it.
@Robert89   Have you enabled roaming on your account?
@Chris_B I have roaming turned on, on the phone. I'm not sure if I need to do anything else?
Solution
Good afternoon @Robert89
Did you manage to get things sorted out with the advice @Chris_B has offered you.
Richard
@Chris_B thank you very much. Phone is now working.
