by Chieftons
New Member
Info on data charges in usa
Could you please advise me on data usage in USA including google maps to navigate
Solution
Re: Info on data charges in usa
Good Morning @Chieftons.
Welcome to the EE Community 🙂
Do you know if you're on a Max Plan?
Our Roaming Page will explain all roaming costs, if you're on a Max Plan you can use your minutes, texts, and up to 15GB of data in the USA at no extra cost.
Hope this helps 🙂
Jon
Solution
Hope this helps 🙂
Jon
