by Gregnorman82
New Member
In switzerland and my phone is blocked
I can’t make calls having arrived in Switzerland
by Brilliant Contributor
Re: In switzerland and my phone is blocked
Hello @Gregnorman82,
Welcome to the community,
Did you not check whether roaming was enabled before going to Switzerland? You may be able to check this by going into your account via the browser, once logged in click on the Menu at the side and then manage devices and scroll down, you will see wehter roaming has been enabled.
Check here for more information what to do:
https://community.ee.co.uk/t5/Roaming/EE-Roaming-What-to-do-if-you-re-having-problems-abroad/m-p/668...
Morning @Gregnorman82
Have you got this working with the advice from @Schockwave?
Hope you're having a lovely time 🙂
