by Cameronm627
In my plan can I use my phone in Ireland I'm going for work
Can I use my phone in Ireland with my plan I'm going for work i called 150 and it said "congratulations you can use your phone abroad in your plan" but I would like to make sure
Thank you
Re: In my plan can I use my phone in Ireland I'm going for work
If you have checked them it should work.
You can also text ROAMING to 150  and you will receive a text confirming.
Also make sure roaming is active on your phone under settings.
@Cameronm627: You may use your UK allowances in Ireland (data limited to 15 GB / month if you have more). However you are expected to spend at least 60 days in UK within any 120 day period to continue to benefit from EE's roaming plans.
EE Employee
Hi and welcome to the community @Cameronm627
Hopefully the information supplied above has helped with your query 🙂
Many thanks,
Lee
