by EmmaDodge Investigator
In South Africa. Phone won't click on to my normal data. Need for uber
Just arrived in SA wanted to click on to data to order uber but it wouldn't. Tried to click on to EE to buy an add on and couldnt connect. I need data for uber whilst I am here and can't rely on WiFi all the time.
10 REPLIES 10
EE Employee
Re: In South Africa. Phone won't click on to my normal data. Need for uber
Hi and welcome to the community @EmmaDodge
So I can try and help please may I know what is displayed when you head over to http://add-on.ee.co.uk/purchase whilst not connected to WIFI?
Many thanks,
Lee
When  I clicked on both the EE app and the text link that came through I just got a loading with a moving circle (ie WAITING) then is said there seems to be a problem please come back.
EE Employee
Hi @EmmaDodge
Go via your web browser rather than the app to the website I provided above.
Does this help?
Many thanks,
Lee
No. I just can't seem to get on to data no matter where I go. Google etc.
EE Employee
Hi @EmmaDoge
What handset is it that you are using?
Many thanks,
Lee
Huawei Pro 10 lite.
It all seems Confusing but going on to EE  via WiFi to look at add ons it seems  I need to buy one for South Africa. I cant use any of my normal inclusive data.
EE Employee
Hi @EmmaDodge
You would need to purchase a bundle for South Africa as your normal allowance would not cover this country.
Have you checked to make sure data roaming is turned on?
Please go to: Settings-More-Mobile Network-Data roaming should be showing a blue tab.
Let us know how you get on.
Many thanks,
Lee
Yes that's on. All the add ons are for Europe and zone A though I'm sure I saw one for SA. Dont worry I will keep digging. Thanks.
EE Employee
hi @EmmaDodge
South Africa is zone B.
Do try a manual network search and choose a different network to what you are using to see if this helps.
Many thanks,
Lee
