by Runnermaid
In Gran canaria no usual welcome text and data roaming not working
by Runnermaid
Re: In Gran canaria no usual welcome text and data roaming not working
It's been activated for as long as ive had the phone and worked fine
previously
Maria
Did you activate roaming on your MyEE a/c before you left? Presumably not. Having a roaming allowance does not auto enable it. You may still be able to in your online a/c under Manage Devices. If not, you will need to call EE. Use the landline nos. in my sig.
by Ace Contributor
Hello @Runnermaid have you been able to use roaming before? If not were roaming and call abroad/premium rate enabled on the account at least 24-48hrs before traveling:
https://community.ee.co.uk/t5/Roaming/EE-roaming-Getting-ready-to-use-your-phone-abroad/td-p/532570
What phone do you have? Try performing a manual network search to see if there are any other networks you can try. More information on what to do when having problems using your phone abroad:
https://community.ee.co.uk/t5/Roaming/EE-Roaming-What-to-do-if-you-re-having-problems-abroad/td-p/66...
Morning @Runnermaid
Thanks for coming here for help.
Has the advice provided got this working for you?
Hope to hear back from you soon 🙂
