by Sunsh1ne
In Cyprus, not able to send calls or texts, worked first 3 days though
In Cyprus, can't make calls or send texts. Both worked for the first 3 days. Used phone in the EU several times previously with no problems. Any advice?
Re: In Cyprus, not able to send calls or texts, worked first 3 days though
Hi @Sunsh1ne
Have you tried restarting your device?  Can you manually select a network under network settings?
Good Morning @Sunsh1ne
Welcome to the community.
I hope you're having a lovely tie in Cyprus.
Have you been able to follow the advice from @Northerner? if yes, has this resolved the issue?
Speak soon,
Katie 🙂
