by JohnnyF
In Cyprus- I get the ‘your service doesn’t allow’ message. ?
Solution
Re: In Cyprus- I get the ‘your service doesn’t allow’ message. ?
Hi @JohnnyF
Log into your on line account and then Menu - Manage Device - make sure you have activated roaming and international calls.
Or
From the MyEE app Current Usage - Controls - activate use phone abroad and make international and premium calls
If you are roaming in the North or near the border you might connect to Turkey network which is outside your EU allowance. Costs for roaming in the North can be found here.
Solution
Hi @JohnnyF
Or
by JohnnyF
Thanks!
