Highlighted
New Member
In Canada 6 Sept to 21st can I buy package for 2 weeks for cheaper calls ETC
I am travelling to Canada on 6 September until 21st and wish to buy a package to keep costs of calls texts and any data down (although do not plan to use much in the line of data if any).
Highlighted
by Ace Contributor
Re: In Canada 6 Sept to 21st can I buy package for 2 weeks for cheaper calls ET
Hi there @Laura456  Have you seen the Roam further add-on? It's one of the best ones EE do in my opinion.
Also check to make sure roaming is enabled, text roaming to 150 now to check!
Enjoy Canada. Where abouts are you going?
