Highlighted
by Investigator
Im currently on the Max plan, in australia however i cannot use my data?
Im currently in Australia and on the Max plan. I cannot use my data from my allowance. I keep getting a message saying i need an add on? I have tried the turn on and off, data, roaming, restart, etc, nothing seems to work. And I have 8Gb of data still remaining. Any suggestions or is this an internal EE problem?
8 REPLIES 8
Highlighted
Re: Im currently on the Max plan, in australia however i cannot use my data?
Did you activate roaming on your MyEE a/c before you left? Presumably not. Having a roaming allowance does not auto enable it. You may still be able to in your online a/c under Manage Devices. If not, you will need to call EE. Use the landline nos. in my sig.
Highlighted
by Investigator
Yes it is activated as iv used my data abroad before.
Highlighted
Hello there @Mjriley
Welcome to the community.
Are you able to make and receive calls and texts?
What phone are you using?
Hope you're having an amazing time in Australia 🙂
Highlighted
by Investigator
Hi Leanne_T,
It seems a bit strage but yes I can receive and make calls  & Texts. Im currently using a Samsung S8.
Still Puzzled as to why is is not working?
Highlighted
by Ace Contributor
Have you got any other data passes on your account as well? This problem has been seen before when the maxtravel pass was on the account.
As you are being redirected to the add-on page then the problem is at the EE end, and I'd suggest calling them and seeing if they can help. May just need to refresh your network settings. That does usually disconnect you though so be prepared to be cut off and maybe call back!
Highlighted
Hi @Mjriley
Thanks for coming back to us.
What happens when you try and access the internet?
Have you tried connecting to a different network in Australia?
Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Speak soon, Leanne.
Highlighted
by Investigator
Hi Leanne,
It tells me I need an add on data bundle. Yea iv tried all the different
networks available.
Highlighted
Hi @Mjriley
What does your plan show as within your My EE account?
Leanne 🙂
Recent solutions
