by Jillian110
New Member
If I text someone with uk number from USA will I be charged?
I am currently on holiday in the USA, I have a uk number and I pay monthly. would I be charged if I texted someone from the uk who has a uk number also?
by Ace Contributor
Solution
Re: If I text someone with uk number from USA will I be charged?
Hi @Jillian110 Unless you are on a max plan, yes. it's 60p a text unless you have a suitable add-on.
Price Plan.
by Ace Contributor
Solution
Price Plan.
Good Morning @Jillian110.
Welcome to the community all the way from the USA 🙂
I see @chistery has provided you with our Roaming Costs page for the USA.
Do you know if you're on a max plan?
Jon
