by Emmame
If I activate World Select talk and text do I get charged if I reject a call?
If I've activated World Select Talk and text and someone calls me do I get charged if I reject the call or don't answer it (having deactivated voicemail)
by Brilliant Contributor
Solution
Re: If I activate World Select talk and text do I get charged if I reject a call
Hello @Emmame
As you have deactivated your voicemail diverts, you should not be charged when you either don't answer or decline the call.
You will only be charged if the call is diverted to voicemail which can't happen as you have deactivated voicemail diverts.
Solution
Hello @Emmame
Thanks @Inyourbox for the great advice 🙂
@Emmame have a great time!
For full Roaming information see our help pages.
Thanks 🙂
by Emmame
Thanks both!
