by Nishma2805
I've no 4g signal in croatia
Hi, I'm currently in Croatia and have been using 4g since I got here. However, it seems to have gone off. I've not changed any settings - so I don't understand why I can't get 4g anymore on my phone. Please help! Nish
by Ace Contributor
Re: I've no 4g signal in croatia
@Nishma2805 Try to search network manually and select different network,
some time turning phone off and on can help.
Many Thanks
Hi @Nishma2805,
Welcome to the EE Community. Smiley Happy
Can you still make calls and send/receive texts?
by Star Contributor
Star Contributor
Try and manually roam on T-Mobile HR as they are most likely to be EE's roaming partner there.
