by harryijones
I've lost coverage in Poland and can't roam. How do I get it back?
Read more
I came to Poland today and although I could roam to begin with, since my phone died I haven't been able to get any coverage. It just says "searching" in the top left corner.
Re: I've lost coverage in Poland and can't roam. How do I get it back?
@harryijones  If I was working then it is the network there that is not allowing you to connect.   Have you tried a manual network search ?
by harryijones
How would I go about doing that?
Hi @harryijones
Welcome to the EE Community 🙂
@Chris_B is correct, it seems that your phone is set up for roaming as you were able to connect originally.
You can see information on how to do a manual network search and some other roaming troubleshooting on our Roaming with EE - What to do if you're having problems abroad support article.
Let me know if this helps and I hope you enjoy the rest of your trip. 🙂
