by KK1982 Investigator
I used a SIM card in the UK and it worked but now is not working in Germany.
I bought a SIM card in the UK, tried it and worked perfectly fine. I travelled to Germany (Berlin) and although it says 4G+, I cannot connect to the internet or use the browser nor WhatsApp. My phone is unlocked and I tried the automatic selection of the network with no avail. I read that you had to send a text message to 150 with the message ROAMING but I didn't do that in the UK and now I cannot do it from here in Germany. I
this the issue? If so, how can I fix it?
8 REPLIES 8
Re: I used a SIM card in the UK and it worked but now is not working in Germany.
@KK1982 : You would have bought a PAYG SIM. You don't need to text ROAMING to 150 on PAYG; they are auto enabled for roaming. It should work throughout the EU.
Do you have credit on it or a Pack or Add-on?
What exactly does texting AL to 150 report?
Good Morning @KK1982
I hope you're having a lovely time in Berlin.
Did you make a call or text whilst in the UK? we recommend you do this before travelling abroad with a new SIM as the SIM needs to connect to the EE network.
Speak shortly,
Katie 🙂
I browsed with it in the UK, but didn't make any phone calls nor did I send any text messages
I cannot call, nor send messages, nor use the data. The only thing I can do is use the free wifis.
I have a Pack of £15 for 3GB with the add-on of 10 GB
Thanks for confirming this @KK1982.
It would require you to make call or text message to activate, as soon as your back in the UK and make a call or text the SIM will activate.
Katie 🙂
By the time I'm back to the UK I won't need the SIM. Is there a way to activate it from here?
I thought it was already activated since I browsed with it in the UK.
Hi @KK1982
Unfortunately there is no way for us to activate it now you are outside the UK. The SIM will automatically activate when you return and use the SIM for a call or text.
Thanks,
Katie
