by Nickfitch
New Member
I need to change my swappable add on and it wont let me?
by Ace Contributor
Re: I need to change my swappable add on and it wont let me?
Hi @Nickfitch
Welcome to the EE Community,
you can change your swappables every 30 days if your experiencing problems beyond that if you give customer services a ring on 150 they will be able to change your swappable for you.
Thanks,
David.
