by andyhaz68 Established Contributor
I need to activate roaming
I'm in Thailand for a fortnight but my roaming doesn't work, it says it's expired but I'm on the 4gee max plan
Re: I need to activate roaming
Good Morning @andyhaz68
Are you able to make calls and send texts?
The Max Plan doesn’t include roaming in Thailand, you would need to purchase a data add-on to use any data.
Full charges for using your phone in Thailand can be found on our Roaming in Thailand Help page.
Thanks, Leanne 🙂
