by ngroom Investigator
I'n in Spain from UK and can't call home due to 'conditional call forwarding'
8 REPLIES 8
Re: I'n in Spain from UK and can't call home due to 'conditional call forwarding
@ngroom: Did you activate roaming on your EE a/c before you left UK?
Try logging into your My EE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
Morning @ngroom
Has the great advice from @XRaySpeX, helped you make calls from Spain?
If not, what phone are you using?
Are you able to send texts?
Speak soon, Leanne 🙂
After very helpful discussions with EE and suggestions on this page the problem has not gone away but mutated: in some parts of the country I can call, in other parts in need to add 00 at the beginning of the number, in yet other parts I can only use the call-back function from a message, and still in some places I get the same error code and can't get through due to 'conditional call forwarding active'....
Hi @ngroom
Does it seem to depend on which network carrier that your phone connects to throughout your travels?
that must be the reason - thank you! I'll talk to EE about whether I can fix the network
Good Morning @ngroom.
Which network are you connected to?
Are you able to clear the conditional call forwarding or do you need it set up?
Jon
Hi Jon
Thanks! I'm trying to clear it, but now I know I can use the 'phone in certain areas I'll leave it until I get home
No problem @ngroom.
If you need any further help just let us know!
Enjoy your time in Spain 🙂
Jon
