by Hande
I’m using payas u go, I’m outside UK can’t call UK numbers, please help
I’m using payas u go, I’m outside UK can’t call UK numbers, could you please help
6 REPLIES 6
by Brilliant Contributor
Re: I’m using payas u go, I’m outside UK can’t call UK numbers, please help
Hello @Hande ,
Welcome to the community,
You may want to take a look here, as you should find the answers if you have not already done so:
https://community.ee.co.uk/t5/Roaming/EE-Roaming-Help-when-abroad-with-your-EE-phone-or-device/td-p/...
Where are you? If outside EU, do you have credit to make calls?
by Hande
I am in Turkey. I have £5 data top up and £1 voice pack. I receive SMSes but unable to call or send messages. I get the prompt that this number is barred from calling. I see the network bars so I have no idea what to do. I cant even call EE customer support.
@Hande , take a look at the link I have included above, you should then find that your mobile should work ok.
You're not within the EU. Your packs are useless there. You need actual credit (£££) to make calls & texts.
Hi @Hande
Welcome to the community.
As @XRaySpeX pointed out, you'd have to have some credit or a roaming add-on to use your phone in Turkey.
Find costs for using your phone in Turkey >
