by Jjs123
I’m travelling to Bulgaria, will I be able to use my data and other allowances
Solution
Re: I’m travelling to Bulgaria, will I be able to use my data and other allowanc
@Jjs123 : Yes, it is part of EU. You may use your usual allowances there with up to 15 GB data per billing month if you have more.
If you are on contract, remember to text ROAMING to 150 before you leave to check roaming is enabled on your account.
Solution
Recent solutions
