by Jneux
I'm roaming in Germany and unable to access Telekom
Cannot access Telekom in Germany, I have O2 but not very good in Ruesselsheim. In the past I had excellent connection with Telekom but now cannot register
EE Employee
Re: I'm roaming in Germany and unable to access Telekom
Hi Jneux,
try changing the network you are connected to as that carrier might not support roaming currently.
EE Employee
Hi @Jneux and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
