by Garsel
I'm on pay as you go VIP pack, can I use a Euro pack before travelling?
I am on pay as you go - VIP pack - I'm wondering can i use a Euro pack whilst in Greece - if so how do I get one?
If not, do normal roaming charges apply for Greece ? 4.4p per min calls and 1.8p for texts - and do I just add enough credit prior to travel and it just comes off this?
by Profile closed
Not applicable
Solution
Re: I'm on pay as you go VIP pack, can I use a Euro pack before travelling?
Hello @Garsel there is no Euro PAYG pack that would replace your UK special offer pack instead you would buy a data/minutes/texts roaming add on to use with your special offer pack still remaining on the account. Here is a link to the roaming tool where you can check the charges and add ons available for your destination. :):
https://explore.ee.co.uk/roaming
by Profile closed
Not applicable
Solution
