by Allishamarshx Investigator
I’m on max plan can I use my phone in Las Vegas with no extra cost ?
I’m on max plan id like to know if when I’m in Las Vegas I could use my phone, minutes texts and data with no extra cost? If that’s part of my plan or not
Solution
Re: I’m on max plan can I use my phone in Las Vegas with no extra cost ?
Thanks I took mine out in December so I should be covered to get my usage for free thank you !!
7 REPLIES 7
by Ace Contributor
Hello @Allishamarshx Las Vegas (USA) is included in 4GEE MAX plans taken out on or after 10th May 2017.
Solution
by Ace Contributor
Yes a 4GEE MAX plan taken out in December 2017 will include USA roaming.
Make sure roaming has been enabled on your account at least 24-48hrs before traveling:
https://community.ee.co.uk/t5/Roaming/EE-roaming-Getting-ready-to-use-your-phone-abroad/td-p/532570
Thankyouuuu !
by Ace Contributor
You are welcome. Enjoy your time abroad the community is here anytime if there is anything else you would like to know.
Be aware that your data is limited to no more than 15 GB per month.
Hi @Allishamarshx
Welcome to the community. 🙂
I see your questions have already been answered.
Please make sure you text ROAMING to 150 to make sure that your SIM is enabled for international roaming.
Have an amazing time. 😄
