by Mikeatt Investigator
I’m on a new Max plan, what will roaming in the USA cost?
Re: I’m on a new Max plan, what will roaming in the USA cost?
Nothing.
As per EE roaming page
Hi @Mikeatt,
Welcome to the EE Community.
Did the useful link @Northerner posted give you all the information you needed?
by Ace Contributor
Don't forget to check roaming is enabled before you leave.
Text ROAMING to 150 (it's free) before you travel.
You'll get a text either confirming you're set up, or telling you how to set up roaming on your device.
