by Ahiggins
New Member
I'm in turkey and outgoing calls are blocked
Re: I'm in turkey and outgoing calls are blocked
@Ahiggins  Login to your online account and enable call abroad and premium rate numbers then restart the device.
by LikeaWine
Is that the same as switching on Roaming?
Hi there @LikeaWine
Welcome to the community.
Calling Abroad and Roaming are two separate options which both need to be active to be able to use your phone outside the UK.
Katie 🙂
