by Clairelizzie22 Investigator
I’m in Turkey and trying to turn my voicemail off texting 150 is not working
Re: I’m in Turkey and trying to turn my voicemail off texting 150 is not working
Thanks for your message
For some reason it’s not letting me send text messages can you advise what I need to check to make sure I haven’t turned anything off. Many thanks
Claire
Hi @Clairelizzie22
Welcome to the community, I hope you're having a lush time in Turkey. 🙂
Did you text VM OFF to 150? If that doesn't work, could you try VOICEMAIL DIVERT OFF to 150?
Let me know if either of those work.
Thank you the weathers lovely
have tried again to send a text message they won’t send.
Tried to fill an online form in won’t get past the photo capture
Anything else I can do not calling as it’s £2 a minute
thanks
Thanks for trying again, @Clairelizzie22
Could you try doing a manual network search and try sending the message from a different Turkish operator?:
Device type Actions
Apple Settings > Carrier > Toggle Automatic OFF
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Settings > Mobile Network > Network Selection > Tap on start manual search
Let me know if that works.
Recent solutions
