Highlighted
by Investigator
I’m in Mexico. For some season I can’t phone home to a local address.
All of the above. Got the max plans and pay above £220 a month but I’m thinking of leaving now coz I have been with EE for so long I wouldn’t change
13 REPLIES 13
Highlighted
by Investigator
Hi
I’m in Mexico. Trying to phone home to when I have a max plan
Highlighted
Re: I’m in Mexico. For some season I can’t phone home to a local address.
Hi @Scott_c-1979
Log into your online account and ensure roaming and international calls are activated.
How old is your Max plan? Did you take it out after 10/05/17?
Highlighted
by Investigator
The oldest one was 2018
Highlighted
by Investigator
I should clarify a UK address not a Mexican one.
Highlighted
by Investigator
Yes only bought iPhone Xlast year. My iPhone XS was within 3 months. My pad pro was bought maybe just about November 17 for me to go on holiday
Highlighted
by Investigator
I have over £160gb data. Not used any hardly any of it. I just need to find a way to be able to phone back to UK before any problems happens and I need I thought EE would offer 24/7 customer service espcially when they offer max plan knowing that there is a time difference
Highlighted
Hi @Scott_c-1979
Welcome to the community, I hope you're having a lovely time in Mexico so far. 🙂
What happens when you try to call? Are you adding +44, dropping the 0 to the beginning (e.g. +44 7953 966 250 instead of 07953 966 250)?
Did you check the roaming status in My EE account?
Highlighted
by Investigator
Yes it is. Not letting me phone I’m
Highlighted
by Investigator
UK
Highlighted
by Investigator
I’ve just been off to to phone to EE and it’s still not gojng
Highlighted
by Brilliant Contributor
@Scott_c-1979, If you are still having trouble and you are in Mexico, have you also tried 0044 and then the number? Either +44 or 0044 should work if roaming is enabled on your account, which you should be able to check via your account via the web, or have I misunderstood something here?
Highlighted
Did you activate roaming on your EE a/c before you left UK?
Try logging into your My EE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
Highlighted
Hi @Scott_c-1979
Have you been able to activate roaming within your My EE account if this was not set up for you?
Hope to hear back from you soon.
Recent solutions
