Highlighted
I’m in Lanzarote and phone says ‘no service’ what can I do to sort it?
Highlighted
Solution
Re: I’m in Lanzarote and phone says ‘no service’ what can I do to sort it?
Hello there @KimWindle
Hope you're having an amazing time in Lanzarote and the weather is good 🙂
Have you tried a manual network search;
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
If so and this hasn't worked for you, can you try logging into your My EE account online go to Menu > Manage Device > Roaming Abroad and also Call Abroad and Premium rate> They will show as ticked if roaming and calling abroad is activated.
If they are not ticked, can you activate these settings?
Speak soon, Leanne.
Highlighted
Solution
Speak soon, Leanne.
Highlighted
Hi @KimWindle
You need to log into your online account and activate roaming and international calls. (Menu - manage your device)
Then restart your device.
It can take up to 24 hours to fully activate roaming.
Highlighted
Thank you so much for your help, I’m now working!   Thanks.
Highlighted
Brilliant @KimWindle
Have a fab time 🙂
