by Dermot68
New Member
I'm in Ireland and have no ee network connection
Re: I'm in Ireland and have no ee network connection
@Dermot68   Did you activate Roaming on your account ?  You might still be able to do this if you login to your online EE account and under manage this device you can enable it from there.  You also need to enable call abroad and premium rate numbers.
Hi @Dermot68
If you can follow @Chris_B advice and let us know if this works for you 🙂
Speak soon.
Leanne 🙂
