Highlighted
I’m in France and my phone won’t make outgoing calls...
I’ve just arrived in France, my phone will receive calls but won’t make an outgoing call. Help!
Highlighted
EE Employee
Re: I’m in France and my phone won’t make outgoing calls...
Hi @Matthewwoodyatt and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Android: Open the Settings menu >Tap More > Mobile Networks > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
