by Kaden2001
New Member
I’m going turkey tomorrow, how much would it cost to use my data?
Re: I’m going turkey tomorrow, how much would it cost to use my data?
Hi @Kaden2001
Firstly you should text ROAMING to 150 to ensure your service is activated.
Turkey isn't within any EU allowance so you will need an add-on to reduce your roaming cost. Roaming costs and add-ons can be found here.
Good Morning @Kaden2001
Welcome to the community.
I can see @Northerner has given you some great advice for using your phone in Turkey.
If you have a pay monthly account, before you go check you're set up for roaming to use your phone in Kiev, to check this log into your My EE account online go to Menu > Manage Device > Roaming Abroad and also Call Abroad and Premium rate> They will show as ticked if roaming and calling abroad is activated.
Hope you have a great time 🙂
