by Lilkaz
New Member
I'm going to gran canaria, will I get charged for using my phone, ie making call
Hi I'm going to gran canaria, will I get charged for using my phone,  ie calls texts ect .
Solution
Re: I'm going to gran canaria, will I get charged for using my phone, ie making
@Lilkaz  Hi, as Gran Canaria is part of Spain and you can use your allowances whilst in the EU you will be able to use your allowances whilst you are there, just text roaming to 150 before you leave the UK you can do this now if you wish so you’re all set
just to add you can use up to 15 GB of data per month if your contract has this or more.
Solution
