by Kipper1
I’m going to New Zealand can I use my phone there
I’m going to New Zealand can I use my phone there including what’s app
Solution
Re: I’m going to New Zealand can I use my phone there
You may use it but whether it costs extra depends on which plan you are on. If it is an EE Max plan from after 10 May your UK allowances are usable in NZ.
Remember to text ROAMING to 150 before you leave to check if roaming is enabled on your a/c.
Solution
