by Johnsot
New Member
I'm going to Mexico in 2 weeks do I need a package or can I use my plan
by Ace Contributor
Solution
Re: I'm going to Mexico in 2 weeks do I need a package or can I use my plan
If you do not have the Max plan that includes free roaming in Mexico, then you might be interested with the roam further add-on.
https://ee.co.uk/help/help-new/offers-and-services/passes/what-is-the-roam-further-pass
W
by Ace Contributor
Solution
W
Hi @Johnsot
Welcome to the community. 🙂
I see @winston  has already advised you brilliantly here.
Make sure you check your roaming is set up before you go. You can do this through your My EE account or by texting ROAMING to 150.
