by Bwilkinson_99
I'm going to Iceland, do I need to do anything to get my allowance There?
I've seen multiple posts about roaming not working when you first get there? Is there a way I can sort this out before I fly?
Many thanks!
Solution
Re: I'm going to Iceland, do I need to do anything to get my allowance There?
@Bwilkinson_99  Text ROAMING to 150 before you leave the UK you can do this now if you wish.   Once there your at the mercy of that roaming network and its network infrastructure.
Solution
Hi @Bwilkinson_99
Welcome to the community. 🙂
I see @Chris_B has advised you to activate your roaming before you go.
Where are you off to? If it's outside of the EU/EEA zones, you can find costs and add-ons on our roaming tool.
Find out more about what to to before you travel >
