by Gpx
New Member
I’m going to Greece, can I use my normal data
by Skilled Contributor
Skilled Contributor
Re: I’m going to Greece, can I use my normal data
Unless you're on a access (restricted) plan or a Galaxy/Apple Watch line, then yes. Data roaming in Greece is within every other Pay Monthly, Sim Only and Pay As You Go
Good Afternoon @Gpx
I love Greece, what part are you visiting?
You can use your allowance as you would in the UK at no extra fee, please be aware you can only use a maximum of 15GB of your data whilst roaming.
I would recommend ensuring roaming is active on your account by texting ROAMING to 150
Katie 🙂
