by Jenna90 Investigator
I’m currently on holiday in Malta & can’t make any calls please help??
6 REPLIES 6
Re: I’m currently on holiday in Malta
Hi
This still has not worked! Anything else?
Sent from my iPhone
I’m on contract & did not text roaming before coming away but I have done this while being away & still not able to make calls
Sent from my iPhone
EE Employee
Re: I’m currently on holiday in Malta & can’t make any calls please help??
Hi @Jenna90  and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Android: Open the Settings menu >Tap More > Mobile Networks > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
@Jenna90: Are you on contract or PAYG? If on contract, did you text ROAMING to 150 before you left UK to check if roaming was enabled on your a/c?
by elena3
New Member
Hi!
I'm on holiday in Austria and have the same problem. I've tried switching network manually but still can't make calls or text. I did not text ROAMING to 150 before leaving the UK, but can't do that now that I'm abroad. I also can't call EE customer service because calls don't work. I would appreciate some help with this, thank you.
EE Employee
Hi @elena3 and welcome to the community.
So I can try and help may I know are you able to receive calls/texts?
Many thanks,
Lee
