by Andynez77
I'm already abroad but haven't set up roaming can't call EE to fix it
I'm in Spain & can't contact EE to fix not having roaming set up
Re: I'm already abroad but haven't set up roaming can't call EE to fix it
Hi @Andynez77
Log into your online account and then menu - Manage device, make sure you have activated roaming and international calls.
Or
From the MyEE app current usage - controls, activate use phone abroad and make international and premium calls
Hi @Andynez77
Thanks for posting on the community 🙂
If everything that @Northerner mentioned is all already set up, or if it still isn't working after, please try manually selecting a different available network:
  • iPhone > Settings > Mobile Data > Network Selection > Turn off Automatic
  • Android > Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows > Settings > Mobile Network > Network Selection > Tap on start manual search
Hope you are all up and running now and having a great time in Spain 🙂
