by Ifu01307 Investigator
I'm abroad and can recieve calls and texts but cannot make calls or send texts?
6 REPLIES 6
by Profile closed
Not applicable
Re: I'm abroad and can recieve calls and texts but cannot make calls or send tex
Hello @Ifu01307 what phone do you have? Try restarting it and/or trying a manual network search to see if there are any other local roaming networks available. 🙂
Good morning @Ifu01307
Thanks for coming here.
Do you hear an error message when you try and make a call?
Are you with us on pay as you go or pay monthly?
Speak soon 🙂
Read more
Hi leanne,
It just comes up message failed to send and when I go to make a call it just says number not recognised.....very odd as I can use WiFi, recieve texts and calls, etc.
It's a pay monthly contract and a Samsung galaxy a3 I use.
Read more
Hi leanne,
by Profile closed
Not applicable
Hello @Ifu01307 just to confirm has roaming been enabled on your account? You can check by logging in to MYEE online and navigating to MYEE>Manage device:
https://id.ee.co.uk/id/login
Here is a link containing information on how to check call barring is turned off when using an Android device under 'Making sure your device is set up for roaming'. :):
http://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-using-your-phone-abroad
Thanks @Ifu01307
To get this checked for you I have sent you a private message with a link to our chat team.
They can get this looked into 🙂
Hope you get this sorted!
