by Liamparish18
I'm a T mobile customer. I was wondering if I can use my data abroad?
I'm a T mobile customer, I was wondering if I can use my data abroad for free as I cannot log into my account. Thanks
by Profile closed
Not applicable
Solution
Re: I'm a T mobile customer. I was wondering if I can use my data abroad?
Hello @Liamparish18 yes data roaming is available on T-Mobile. All EE, T-Mobile and Orange are also included in the new free EE EU roaming from 15th June:
http://shop.ee.co.uk/international/travelling-abroad
by Profile closed
Not applicable
Solution
Good Morning @Liamparish18
Welcome to the community.
Please check the link @Profile closed has provided to check the country you are travelling is included 🙂
Also it is best to give us a call before you travel to make sure Roaming is set up for you 🙂
Have a great time!
