by BobW Investigator
I'll be in New Zealand for a month. Can I get an add-on for calls whilst there?
by Skilled Contributor
Skilled Contributor
Re: I'll be in New Zealand for a month. Can I get an add-on for calls whilst the
As bad as navigating the EE site can be sometimes, a quick Google for "EE calls New Zealand" found this page...
http://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/new-zea...
It's a good time of year to be going down-under, enjoy your trip!!
by Ace Contributor
Hi @BobW. It might be worth talking to EE to see if you can upgrade to a Max plan, which includes calls, texts and data whilst in New Zealand. Prices vary, and will depend on what you are on now but if you travel a bit the max plans are good value.
Enjoy New Zealand!
Hi @BobW
Welcome to the community.
Some great advice here already.
I was going to recommend checking out the Max plans too. Definitely worth a look.
Find out more about changing your price plan >
Have a brilliant time in New Zealand.
Chris 🙂
