by Pcl781
I landed in Italy this morning, can't make calls or send texts.
Help. I can't make calls or send texts. I have switched the phone on/off; reset network & reset all settings - all to no avail
Re: I landed in Italy this morning, can't make calls or send texts.
Hi @Pcl781
Thanks for coming to community from Italy 🙂
Before you went away, did you activate roaming? That is potentially the problem.
If not, please see our Roaming with EE - What to do if you're having problems abroad support article.
Some of the hints, tips and tricks may help to get things working for you.
If not, please log in to your MYEE and await a live chat with an advisor.
Let us know how you get on.
Richard
