by B3ck
I keep getting a no internet message when connected to wifi?
I keep getting a no internet message when connected to wifi at work and home anyone know why?
Re: I keep getting a no internet message when connected to wifi?
@B3ck   What device is it ?
Have have you tried forgetting the wifi networks and re-entering the password to re join the wifi network?
by B3ck
Iphone SE
I have to fill in my work password for wi-fi each time I use it but it still happens
@B3ck  The device should remember the password and you shouldn't need to enter it each time.
But but please give this ago.
 Navigate to settings/General/reset/reset network settings.  This will make the device shut down and reboot and as it says will reset all network settings.   You will need to put your wifi passwords back on the device after this as it will wipe them from the device in doing this.   No other information will be wiped.
