by Flok77
I havent topped up my number for some time until today, but my number is off
I haven't used my UK number for some months and until a month ago i received messages. I cannot be called or call anymore, even though today i topped up with 15 pounds.
Does anybody know what I need to do to make it function again?
it is a prepaid
Solution
Re: I havent topped up my number for some time until today, but my number is off
Sounds like it has gone into hibernation.
When did you last use it for a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
Solution
by Flok77
thank you so much!
It was like you wrote to me. I called +44 800 079 8586 from another number and they activated my number again. Which should be working within 24 hours.
Thank you again for your help
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
Recent solutions
