by Tricky1959
New Member
I have the roam further add on what networks are used in usa and canada?
I need to know the networks used in usa and canada. So I can use them.
Re: I have the roam further add on what networks are used in usa and canada?
Hi @Tricky1959,
Don't worry, your phone will automatically connect to the correct network when you are roaming.
Don't forget to text ROAMING to 150 before you travel to make sure your phone is ready to use abroad.
